Winisd Pro Question
Spddracer
Sounds Goooooood
When you put the series res. in winisdpro is it supposed to be .2 ohm or 2 ohm for a 2 ohm series resitance ?? Are you to put the decimal point in or not ?? if i dont i have a huge peak if I do it is a nice flat curve ???
Originally posted by Spddracer When you put the series res. in winisdpro is it supposed to be .2 ohm or 2 ohm for a 2 ohm series resitance ?? Are you to put the decimal point in or not ?? if i dont i have a huge peak if I do it is a nice flat curve ???
no decimal point. the HUGE peak would be because ur amp would be running at a .2ohm load....which most will not even consider handling
Originally posted by Alaxan no decimal point. the HUGE peak would be because ur amp would be running at a .2ohm load....which most will not even consider handling
I thought that in winisd pro , That the seires resitance would be the resistance in the line like.1 ?? Doesnt winisd already know the ohm load of the driver ??
Spddracer
Sounds Goooooood
Spddracer
Ohio
Spddracer
