audio system for honda fit
I personally say go with some raw drivers like the one guy mentioned already from Parts Express.
I have used them quite a bit and perfer them over main stream comps....I have used various mids as you can get them quite cheap off there. Gives you options to choose which one you like, but you did mention you don't have a lot of time to dig in and get your hands dirty.
I think the installer mentioning the Audison stuff must know what he is talking about as theat is good quality stuff. Many high end audio guru's in the SQ field love those.
I recommend getting an aftermarket deck due to the higher pre-outs on the RCA's and more flexability in tuning and what not. You could easily get a nice HU, new front speakers and amp and I recommend deading the doors well to get better mid bass and that should suffice for now till you want to add another amp and small sub. Could always fiberglass a small enclosure on the one side to fit a 8-10" sub.
Good luck!
That ELD thing is crazy!
ok, i want to order some stuff tonight.. Please let me know if this will work.
Hybrid Aduio Claris 61-2 in the front
Hybrid Audio Imagine 61-2 in the rear
I know the depth of the Claris is pretty deep. Will it be able to fit in the Honda Fit? Do car stereo installation places have adapters that will make it fit? And for the rears, shall i do 61-2 or 51-2? and why?
ok guys, i pulled the trigger! here's what i ordered online
Pioneer AVH-P4400BH head unit
ARC Audio KS300.4 amp
Hybrid Clarus c61-2 Front
Hybrid Imagine i61-2 Rear
DVD Brake bypass
Pioneer Ipod USB interface
I'll worry about the sub when this stuff comes in. what do you guys think? I think this should sound AWESOME (i hoping //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
280
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
teeforb
teeforb
United States
teeforb
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
