ime, they usually just say dual 4 ohm or dual 2 ohm, nothin elseIf the Nom is 4 and its a Dual voice coil then its a Dual 2......Most sites have the NOm for when it is wired in series
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
X2^^^ this man is a thinker! I'm pretty sure that the .4 v-max's are dual 4 ohm and the .2 v-max's are dual 2 ohm.. I'd say go with this kicker amp..... http://cgi.ebay.com/KICKER-06-ZX750-1-750W-Mono-Car-Subwoofer-Amplifier_W0QQitemZ250109072666QQihZ015QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
whats wrong with power acoustik ... j.w my freind has one and it works fine
I read the manual i think its say if you series wire the 15.4 then it will be 8 ohms and if you parelle wire it it will be 2 ohms
If you had ever been around the Lanzar Optidrives, you would NEVER place Lanzar in the same category as those other two ever again. Outstanding amplifiers, classics now. Normally Id agree Lanzar is not a great name otherwise however.I think you have been given some solid suggestions... legacy, lanzar, power acoustic... are low end amps that should not be considered.
