Are thest good enough amps....noob
sk8erboyla2004
La
im a noob naturally i wanna find a good amp to power a 15.4 Cerwin Vega VMAX heres some of my selections since most amps dont give the true watts stated
my freind a know it all said i should get a 2400 watt amp and hardly turned it up to get true watts to it w.e man im just gonna bridge my speaker into a 4 ohm single load
These are the specs for my sub
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16864
Legacy
http://www.millionbuy.com/lcyla1459.html
http://www.millionbuy.com/lcyla1868.html
Lanzar
http://www.millionbuy.com/lnzmxa242.html
Boss
http://www.millionbuy.com/bosbl1400.html
Power Acoustik
http://www.millionbuy.com/pakov21800.html
I came to this forum becasue everyother forum sucked this one has more people and hopefully ill get replies and not get bashed for being a noob
Legacy
Lanzar
Boss
Power Acoustik
first.. your friend is an idiot, that subs rms is only 600 watts, with a quality amp, you wont need 2400 watts
http://www.cerwinvega.com/VMAX15.php
spend the xtra and get... http://cgi.ebay.com/ALPINE-MRP-M650-Mono-Sub-Class-D-Amp-Amplifier-New-07_W0QQitemZ140112602245QQihZ004QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
if its a dual 4 ohm voice coil, it can be wired in to 2 or 8 ohms
if its a dual 2 ohm, it can be wired in to 1 or 4 ohms
if its a single 4 ohm coil, it can only be wired up 4 ohms
....2 coil, can be only wire up 2 ohms
you really need to find out what it is, i'd contact CV
sk8erboyla2004
sk8erboyla2004
La
sk8erboyla2004
