Are these the same amp? And is this common?
LetMyBeatPound
CarAudio.com Exclusive
I was looking at a video about a Skar RP2000.1D and it seems to be an almost exact same amp as my Alphard M2000D. The sides and aluminum heatsink shell ridges are the same looking even the dimensions and out numbers are even the same. Is it possible they are the same amp just different names? Or are these just the same board and shell but use different internal components? What are opinions about the Skar brand? Good? Bad? Or just Midway not great but not terrible?
Yes, they're probably identical, and yes it's incredibly common. There's people who will fall over themselves saying otherwise to justify the extra money they spent on their "brand" of the exact same thing, but typically without precision test equipment performance will be indistinguishable. Not like any of these companies actually design anything. They just buy from a catalog from the only 3 factories that mass produce this stuff for export.
yeah it weird the sound qubed amps are same as some hifonics amps but the hifonics actually had better caps lol.. lot of the ts amps are similar to orion, xtr and wolfram that y it's good that we have bigblank to test amps now..
Well hell to the yeah then...
BigDWiz - Referbished Skar RP2000.1D AmpDyno
If this is the same amp, then I'm even happier with my amp now. He got 2250w RMS @ 1% THD at 13.8v, 2400w at clipping @14v, and 2670w RMS @ 1ohm on a Dynamic run at 14v. So that would me my lil amp is a beast... I can't wait till everything I ordered comes in...
Thanks for everyone's replys!
damm it.. either way 2 ohm more efficient..
Yea even the bass knob that came with mine is exactly the same. I think for $220 I may order one instead of a M2000D just because its $60 cheaper. I it is a good amp even when I try to torcher it it don't get too hot but I'm gonna put fans on it anyway I got 2 heavy duty 5" computer fans just need one more
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
629
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
LetMyBeatPound
LetMyBeatPound
Albuquerque, NM
Boomin_tahoe
    May 22, 2024
SPLBassJunkie
    May 21, 2024
