Aq supertweet mounting?
But if you have ~20 watts going to them why not just use HU power? Just curious
I have 4 AQ's per A pillar....
---------- Post added at 02:51 AM ---------- Previous post was at 02:51 AM ----------
Yea i will be running.them on front 2 channels of ppi bk800.4 and 4 6.5 aq on the rear channels bridged
that should sound very good and get quite loud when it's all dialed in.
AQ supertweeters FTW...
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
5K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
NASTY08IMPALA
NASTY08IMPALA
LOUISVILLE, KENTUCKY
mlstrass
saints747
    May 7, 2024
saints747
    May 7, 2024
