Aq supertweet mounting?
I have mine mounted in the A pillars and in the wife's van they're in the dash.
They're only 1 1/2" deep, so not that hard to mount actually. Single one in the A pillar isn't that bad, but you need to go around 3 3/4" wide.
i have mine mounted in the a pillars and in the wife's van they're in the dash.
They're only 1 1/2" deep, so not that hard to mount actually. Single one in the a pillar isn't that bad, but you need to go around 3 3/4" wide.
i have yet to pull off the pillars to see how much room i have guess ill try that first..yea just doin 1 in each pillar
You just have to build out some off the A pillar. Make a baffle ring and hot glue it in place with spacers, wrap it, FG, sand it smooth, cover...done
I was thinking about doin near 6.5 waist level maybe keep down on the harshness
Too much power makes them harsh, otherwise it's not a problem. I have them reflecting off front windshield and they sound very good, not harsh at all. Probably getting about 20watts each if that...
Really? I thought you wouldn't even be able to hear me with only 20 watts going to me lol I thought they had to have lots o power
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
5K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
NASTY08IMPALA
NASTY08IMPALA
LOUISVILLE, KENTUCKY
mlstrass
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
