AQ pre production 2.5 sub
i dont like the wire they have instead of two terminals. what do you do to connect to the amp,use a soldering iron or what? I think it seems kind of inconvenient.
i thought it sucked too...until i used them. they work just dandy, and hardly inconvinient.
x2 wire up your speaker wire to the woofers wires with wire nuts and I usually put electrical tap around that as well, just for extra measure. All DD and AQ subs use the wire instead of posts/terminals.
egg
I braid mine together, then heat shrink, then tape them. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I hate wire nuts, they're an expense that can be done without, and have an even better hold. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
What's so hard about twisting wire together? You can twist and tape, or use a wire nut.
Much easier than trying to jam a couple decent sized wires in some terminals.
Here is a picture of the new pre production I guess its called the AQHDC2.5 subwoofer, It looks chopped up cause I had to remove the background, I hear it has a smaller motor than the HDC3 and it has 2.5"VC. Anways heres the pic of it
egg
aww its a cute little guy
like lilmanic said, comin from same place, the c stands for chinese, says dj himself, so no american made...
as long as the build is still good, pounds, and a lil cheaper, plz don't complain...
cus things are made in the us, does it mean its better then other places? not always, and there's plenty of examples of where that is the case...
SPL140.2
Team DefJ
SPL140.2
NY
Haunz
