4.99 a foot. and if you tried it you would love it. Aslo, with the fusing, if you look at his diagram, hes already got the third battery(the second one in tha back) unfused. Thats why I said, he should either move it over or get rid of it. If it were me I would moun the two batteries side by side so the piece of cable would be like 6 inches long, and they would both be held in by a wooden enclosure. If they were gonna have any distance between them, then yes I would fuse it.
If the batteries are together and there's NO WAY the + wire can touch anything else, cool.Ok ok, sooo. Say I do throw the HC800 out of the picture. What should I do to the HC2400? Fuse 200 amps before and 300 amps after to the colossus? On all these pics I see of multiple batt installs, I never see fuseholders in between batteries.
djman, that makes no seance to have it fused at both ends. THE SAME CURRENT FLOWS THROUGH THE ENTIRE CIRCUIT AT THE EXACT SAME TIME. So why would you fuse it at both ends?
If there is trouble(short) between EITHER battery, I'D want a fuse near each.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifdjman, that makes no seance to have it fused at both ends. THE SAME CURRENT FLOWS THROUGH THE ENTIRE CIRCUIT AT THE EXACT SAME TIME. So why would you fuse it at both ends?
wire rub, idiots, cuts in the jacket. Fuses are there to keep your car from going up in flames. It would just **** for someone to jack his amp and then have his car burn up from the wire shorting out.Ok.. thought about it for a second... If the wire falls out of fuse holder, then it could cause a direct short with one of the batteries. So I give it to you in that situation only. You get two failsafes instead of one.. I have never seen it happen.. but I suppose it could
//content.invisioncic.com/y282845/emoticons/yes.gif.2d6d3882a589966b8145fbc57db57f33.gifwire rub, idiots, cuts in the jacket. Fuses are there to keep your car from going up in flames. It would just **** for someone to jack his amp and then have his car burn up from the wire shorting out.I used to run a circuit breaker under the hood too. I used to use it as a kill switch before I had batts in the back. After reading about how circuit breakers work, the FIRST TIME it popped from current draw, I put a fuse holder in. Anyone want it?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
How can you fuse 400 amps? THe only way I know is a dual ANL fuse holder which are like 55 bucks. I don't want to spend over 100 on fuse holders....
