iceteebone
Banned
um if it takes 800A to blow a 400A fuse... it would be labeled 800A. In car audio applications most fusing is fast blow (so you get the benefit your supposed to get from a fuse) Going to a slow blow fuse (one that acts the way Helo is talking) defeats the whole purpose of fusing. Amplifiers are sensitive, you only need to push them a little more then intended and you chance blowing a power transistor. Take your total wattage your system can produce RMS then divide that number by 14 to figure out your amperage. Then add a few to give your self a small cushion and to take into account amp efficiency's. Ex. XX-Colossus =3200W 3200W / 14V = 228.6A (minimum) Why do some many people think the chassis is a bad place to ground? so long as you properly prep the area your grounding to in the back and the area your grounding to in the front (like when you do the big three) then the chassis can handle a MUCH larger amount of juice then the wire you run. It s a bunch of big sheets of metal. there is NO DIFFERENCE electronically between having a solid piece of wire and putting both ends to chassis. A connection is a connection, so long as there isn't resistance being added somehow, or insufficient material to handle the load. My two cents. Oh yeah... You also have 2 200A fuses in series going to your back batteries which does NOTHING for you. Drop one of them. Also, your concerned about having to replace fuses... Why not go to circuit breakers. Like these. Good luck
it's always importan to fuse at each battery and circuit breakers can always fail and you shouldn't be poping breakers or fuses in the first place.
