Any issue with sub distance from wall?
SpeedEuphoria
Basically the subs will be inverted and wanted to know if they can sit just clear of the bottom wall? It will be flush double baffled inverted
I dont think it will really matter but wanted to ask before i make a mistake.
either you are confused or i'm confused. inverted means that the sub is not inside the box. it is mounted with the cone facing insind the box, motor out of the box.
exactly correct
so I' asking if the sub can be right next to the floor of the box, obviously inverted. So the rubber surround will be inside the box and the rim of the sub will basically be touching the floor.
I dont think it matters just asking.
If you dont understand I'll draw a pic
exactly correct
what are the dimensions of you box, im still a little puzzled here, sorry. but yes it matters
The box is large enough with the subs inverted, 4 cubes
But I want to have the subs facing the cabin(inverted) and run vertical ports through the stock 6x9 holes
the issue is having the back seats(when up) clear the exposed magnets. So as low as I can mount the subs in the box will give me the most clearance with the back seat while keeping the trunk sealed from the cabin.
Use the same rule that applies to leaving the motor inside the box (not inverted). Assuming your sub has a pole vent, try to leave at least as much room from magnet to wall as is the diameter of the vent.
SpeedEuphoria
SpeedEuphoria
BCM
audioholic
