How much power will FI SSD's handle?
Wolverine19D
So I have been asking a lot of questions on here and have decided I want 1 FI SSD 15" and 1 18" to put in my Jeep Wrangler. Right now I have a 1500 watt RMS MB Quart amp. It should make those subs sound pretty good for now. But eventually if I want to upgrade my amp how much power will these subs handle together?
Should I get the BP power option for another $30 and what does this do? Or the flatwind coil option for $20? I want to keep as much sound quality as I can and am unsure of what these options do.
Also I would need dual 1 ohm subs for my amp right?
Is there any possibility these subs could handle 2 MB Quart 1500's in the future for daily or am I dreaming?
Thanks guys
do NOT run a 18 and a 15" in the car cabin that wont sound good at all.
def get the flatwound coil option. they can handle safely 1000rms daily and 1500-1800 for burps. alot depends on the encloure with power handling.
Well ****, why wouldn't they sound good? I don't have room for 2 18's in the Jeep. But want as much bass as possible. I guess 2 15's itll be. But what about the FI Q's then? Would they still sound good but be louder than the SSD's? Then in the future it would let me upgrade them more for power. Remember for now they will only be getting 1500 RMS.
You guys are a ton of help, Thanks!
Well guys, I could really use some input as I believe I am going to order them tomorrow. Also do I need dual 1 ohm or dual 2 ohm? Its 2 speakers and I need them to run at 1 ohm with my amp. So I need to know that, and what options to put on the speaker if any. Thanks!
The dual 1 ohm would wire to 1 ohm....
Make sure you wire them in "series" though, that would end in the 1 ohm load......
"Parallel" would be a .25 ohm.....
Wolverine19D
Wolverine19D
West Virginia
KidThump
