any interest in a gain setting tool
Would you buy a Clipping Detector for setting gains?
  • Yes, for around $25
    Votes: 23 59.0%
  • Yes, but not for $25
    Votes: 7 17.9%
  • Yes, and for more then $25 if more features were added
    Votes: 7 17.9%
  • No
    Votes: 6 15.4%
  • Total voters
    39
thch
MSEE, Design Engineer
I was thinking recently about making a clipping detector as an alternative to a DMM. Like a DMM, the device would be handheld, battey powered, easy to use, and cost around $25.
the device would work with a 60hz signal source. standardizing on 60hz makes things simple enough to build.
basically you would plug the device into the amp, then turn up the volume. 4 led would be on the device -- no clipping, 0.1% distortion (or low i guess), 1% distortion, and 10% distortion.
two switches would be on the device -- on/off and line/speaker level input. while it is possible to make an autoranging circuit, it would be more expensive and probably less accurate.
i'm working on the schematic for this. I have a lot of parts. I will build one for myself. I am wondering if there is any interest in either a fully assembeled device or a kit for this purpose.
EDIT -- please select only 1 answer. seems i can't edit the poll.
id pick up one for sure. and some for the local shops, as they dont have a clue. one guy told me "i didnt touch ur gains yet, only your bass boost, a little bit for now, to break in ur subs, come back and i will set your gains"
DMM is more flexible overall.....but this device would take the brain work out of it for someone who frequently sets amplifier gains (like an installer) or someone who has no clue (you know....the people who read the gain setting tutorial then come back with 50 million questions, and after it's all said still has no idea WTF we are talking about).
And yes, an o-scope would again be more flexible overall....but it'd also be >5x more expensive, and if your sole purpose was to use it to set gains there'd really be no reason to get one over this device unless you just wanted to feel cool because you owned an handheld o-scope.
Hell, for $25 I'd probably grab one just for ease of use for when I install in buddy's cars and whatnot.
thch
thch
SIUE
Shyne151
