another sub wiring question
saltyreefguy
i want to use 2 jl12w6v2, which are dual 4ohms, i have yet to find a diagram to wire both of them in either parallel or series, to get a 2ohm output. the wiring calculator at 12volt is for svc not dvc coils, does any know, where i can find a diagram if possible? thanks.
well, after reading jl audio sites, found out the dvc per sub was wired out at nominal 2 ohm output, thus wiring them in series, will get me 4 ohm output, is what i was looking for for my ppi a1200.2 art amp, which will output 1200 watts at 4ohm input, not 2 ohms like i thought. in 2 ohm input it actually decreased to 600 total bridged, instead of 1200@4ohm.
so to sum it up i thought i was looking for 2 ohm input, when it should have been 4 ohm to get the max. bridged wattage out of my amp.
To further simplify this if you have a pair of subs that each sub is a DVC 4 Ohm driver they cannot be wired to a nominal 2 Ohm load together so the amp's output at that load is a rather immaterial figure. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You choices for a final load using those two subs are 1 Ohm, 4 Ohms, and 16 Ohms.
did some reading, and that was what i came up with also, thanks.
well, i hook up the subs today in series, but using the sub wiring calcutor, it came up 8 ohms. 2 dvc4 ohm subs wired in series, it comes up to 8 ohms, and it parallel it give me 2 ohms, is there a special way to wire it so i can get 4 ohms? or am i using the calculator wrong.
i found out that running in series was incorrect? got the correct diagram to get final 4 ohms, after it was all re-wired, can it be checked with a dmm to make sure the ohm rating is correct? or not possible?
also it was recommended for jl audio subs not to be wired in series to be avoided, well i did mistakenly wired them/series and played music on them during trial testing, was there any harm done to them?
anyone can offer some advice on the jumper wires on each sub?
saltyreefguy
saltyreefguy
palmdale, ca
saltyreefguy
