How to check your ground with a DMM?
so put 1 DMM probe on a negative battery post and put the other DMM probe on the ground im checking?
So if it reads more than .1 its a bad ground right, so would sanding it down to bare metal fix the ground?
Depends on how much power you're running. In all honesty, if you can measure the resistance with a normall DMM then the resistance is too high. That's the same resistance as 1000 ft (yes one thousand!) of 0 ga wire. Do a little V=IR math. If your amp is drawing a paltry 30A and your ground has 0.1 ohms of resistance you are losing 3v to your ground resistance and your amp will have 9-11V to try to run on. Most amps I know of will shut down under those conditions.
Like I said you ideally want your ground of low enough resistance that you can't simply measure it directly. You have to figure it based voltage drop under load.
UPDATE: I found and fixed the problem,it was my HU's ground.All i had to do was sand it a little with some good ol 36 grit and BAM! the noise/alt whine was fixed;) Thank you guys for all you help:)
//content.invisioncic.com/y282845/emoticons/nutkick.gif.acc8dcd6c1bd27fba0cbeda5b212085c.gif
GOOD GROUND>ME
CJL
CJL
oZone
CJL
