I can respect that answer because its genuine , how did those words taste , 1st time i hear you say you don't know LOLmilitary grade means the most strenuous specs and codes. just saying from MY stand point any military job has WAY lower tolerances.
---------- Post added at 04:37 PM ---------- Previous post was at 04:36 PM ----------
i honestly don't know. good luck. should go trade that in for a g37.. its faster rides better and has alot more space.. lol
yes , thanksSo you need 2 amps? Well the arc xdi 600.4 bridged does 300x2 at 4ohms
Can't think of a mono amp. Incrimitor is close... little over 7.
Jl xd 4 channels are under 7 but bridged will do less than the arc.
size tires you have on um? you can't get 515 with 8.5 pounds of boost nether.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i can run 275 35s rear without any chamber. and if i do want larger -1-2 can help depending on the tread.I can respect that answer because its genuine , how did those words taste , 1st time i hear you say you don't know LOL
and G37 , NO, you can't run deep lip, low/negative offset wheels , without being forced to use double digit negative camber
it does not have to be the same brand , it would be nice thoughBut it sounds like you want 2 identical brands?
the arc for mids and highs would work your suggestion is goodWell it was 175-300 in your first post. So I give up. Good luck.
the arc KS are basically class AB with another switched high voltage rail. most ABs in reliatly are about 55% efficient the arc is closer to 70.. dammit they are too big. you can mount them anywhere else?the arc for mids and highs would work your suggestion is good
but i could match them and go DD , and the DD 2 ch is probably about the same price as the arc
thanks man, i appreciate it
19 x 9.5 F / 225-35 / + 7size tires you have on um? you can't get 515 with 8.5 pounds of boost nether.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i can run 275 35s rear without any chamber. and if i do want larger -1-2 can help depending on the tread.
its a **** shame the arc is to big. they sound ******* great. better than most of the ABs i've heard.both DD's are under 7"
and I have an option with DD C3D A/B or to use the SS6 full range D class , 550 x 2 @ 4
SA-65CS V.2 Mid in glassed kick panels , tweets glassed in the a-pillarsits a **** shame the arc is to big. they sound ******* great. better than most of the ABs i've heard.its a safe bet to go with the DD though and for highs its a-lot more dynamic so class AB wouldn't be bad but the DD has descrete inputs so its not like the other cheap class Ds they actually sound great.
you cant go wrong with the DD amps..
