Amplifier installation
So can I use that on one set and the other amp on the other set
You can but you would have to pull the wires out the box and wire each 4 ohm sub to each bridged channel on the Jensen. If that Terminator amp came with the first sub set, I assume the subs are single 4 ohms paralleled to 2 ohms, hence the single terminal cup.
That should suffice. Terminator amp will power each sub with 125 watts on a 2 sub set up. This one will power each 150 watts on a 4 sub set up.
Actually has impressive features. Bluetooth controlled amplifier settings and RGB lighting.
Ok thank you for the help
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
245
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
808
fjack
CarAudio.com Recruit
fjack
New York
fjack
    May 24, 2024
