Amplifier installation
So can I use that on one set and the other amp on the other set
You can but you would have to pull the wires out the box and wire each 4 ohm sub to each bridged channel on the Jensen. If that Terminator amp came with the first sub set, I assume the subs are single 4 ohms paralleled to 2 ohms, hence the single terminal cup.
That should suffice. Terminator amp will power each sub with 125 watts on a 2 sub set up. This one will power each 150 watts on a 4 sub set up.
Actually has impressive features. Bluetooth controlled amplifier settings and RGB lighting.
Ok thank you for the help
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
The CT's are nice, That Sundown is a a frik'n beast!
719
733
fjack
fjack
New York
fjack
    May 18, 2024
    May 18, 2024
