Amplifier Channel Query
  • 4
Because you need a 4 ohm load if you're going to bridge the rear Pioneer channels. The 1262 is a dual 4 ohm, which you would have to wire to 8 ohm.
Oh. Almost missed that detail. That Pioneer Amp GM-D8604 looks just right....Thanks you are awesome.
Glad to help man. I ran the 8604 for quite a while and never had any issues with it even getting warm.
CSCStang....One last question. What should I look at while choosing the Radio Receiver(1 DIN). All i needed was one with USB Slot but do i need to worry about matching it with my Amp and Sub or something like that? LIke 2 RCA Preout? Also what brand of Receivers are considered the best?
Pioneer or Alpine head unit. 2 sets of rca out would be ideal.
CSCStang....If i use Pioneer GM-D8604 Amplifier, I will bridge 2 Channels to create 300 W power to feed the SubWoofer (Continuous Power Output Bridged (4 Ω) 300 W x 2). The remaining 2 chanels will provide Continuous Power Output of 100 W at (4 Ω, ≤ 1% THD+N). For that much power, what front/rear speakers were you using with this Pioneer Amp?
GM-D8604 - Class FD 4-Channel Bridgeable Amplifier | Pioneer Electronics USA
I was running a pair of Kappa 6829cf on the front 2 and 2 pwx 8"@8 ohm wired parallel and Bridged @4ohm on the rear.
I ran an older Pioneer GM-6400 for awhile and it worked great running the front channels to apair of Kicker KS comps and the rear bridged to a Polk db104.
Depending on the vehicle you may be able to get away with not running the rear speakers at all.I have a Mini so I was able to delete the rear fillsince such a small area. As far as HU options Pioneer will have you covered just be careful some of them have a goofy knob that I found anoying bc it was like a joystick and rotary knob. Goodluck with your set up
I ran an older Pioneer GM-6400 for awhile and it worked great running the front channels to apair of Kicker KS comps and the rear bridged to a Polk db104.Depending on the vehicle you may be able to get away with not running the rear speakers at all.I have a Mini so I was able to delete the rear fillsince such a small area. As far as HU options Pioneer will have you covered just be careful some of them have a goofy knob that I found anoying bc it was like a joystick and rotary knob. Goodluck with your set up
Thanks TommyDH and CSCStang.... I have been looking and narrowed down on these 2 speakers for the front of the car
1. Infinity - PR6500CS - Infinity Primus PR6500cs 6.5" / 6.75" Component Car Speakers
2. Infinity - Reference 6500CX - Infinity REF-6500cx 6.5" Reference X Component Car Speakers
What do you reckon? To be paired with Pioneer GM-D8604 Amplifier and Infinity 1260W Subwoofer :)
Product Brand & Model: I have a Mosconi D2 100.4 DSP amplifier and Controller for sale. It's 4 channel amplifier with a built in DSP. Condition...
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
Yep, i am going to put those audisons (rainbows dont fit) on original places front and focals to the Back end. I am going to give amp and corals...
I think I mentioned plenty of amps for the need. hopefully you were able to pick one up on the Christmas sales
4K
Guddddu
Guddddu
Santiago
CSCStang
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
