Amplifier Channel Query
Guddddu
Hi All
I have a Factory Audio Configuration. There are two Tweeters and Four Speakers ( Front Right, Front Left, Back Right, Back Left). I am looking to add a Amplifier and I am also looking to add a SubWoofer. I am confused as to what Amplifier to get. I saw the following three options
Sony XM-N1004 - 4/3/2 Channel Stereo Power Amplifier
Sony XM-N502 - 2/1 Channel Stereo Power Amplifier
Sony XM-GS400 - 3 Channel GS Series Amplifier.
Sony XM-GS100 - 1 Channel GS Series Amplifier.
If i need to power all 4 Speakers and the SubWoofer then which amplifier of the above will suit me?
Or shall i look at powering only 2 Speakers and the Subwoofer. In this case which 2 speakers shall i Amp and which amplifier of the above will suit me?
Please help me with some ideas as I am new to Car Audio Configurations.
Yes. Much better than the Sony. Infinity does have 5 channel amps btw. Check out a Kappa 5. Wire that sub in parallel for a 2 ohm load.
Thanks CSCStang. The 5 Channel Amp is totally going over my budget. I am thinking a 4 Channel and amping only 2 front speakers and the sub while leaving the rear 2 without AMP. Does this config make any sense?
Yeah you can do that. Check out a gmd8604, 4 channel Pioneer. Run the front 2 off the front and bridge the rear to run the sub.
Yeah you can do that. Check out a gmd8604, 4 channel Pioneer. Run the front 2 off the front and bridge the rear to run the sub. Look at getting the 1260 sub though, 4 ohm svc.
Guddddu
Guddddu
Santiago
CSCStang
