Amplifier Channel Query
  • 4
Guddddu
21
Santiago
Hi All
I have a Factory Audio Configuration. There are two Tweeters and Four Speakers ( Front Right, Front Left, Back Right, Back Left). I am looking to add a Amplifier and I am also looking to add a SubWoofer. I am confused as to what Amplifier to get. I saw the following three options
Sony XM-N1004 - 4/3/2 Channel Stereo Power Amplifier
Sony XM-N502 - 2/1 Channel Stereo Power Amplifier
Sony XM-GS400 - 3 Channel GS Series Amplifier.
Sony XM-GS100 - 1 Channel GS Series Amplifier.
If i need to power all 4 Speakers and the SubWoofer then which amplifier of the above will suit me?
Or shall i look at powering only 2 Speakers and the Subwoofer. In this case which 2 speakers shall i Amp and which amplifier of the above will suit me?
Please help me with some ideas as I am new to Car Audio Configurations.
Can a 4 Channel Amplifier be used to power 4 Speakers and a SubWoofer?
Not the best idea. If you can't get a 5 channel, then get a 4 channel and a mono block for the sub. The Infinity would be a better sub than the xplod.
Yes. Much better than the Sony. Infinity does have 5 channel amps btw. Check out a Kappa 5. Wire that sub in parallel for a 2 ohm load.
Thanks CSCStang. The 5 Channel Amp is totally going over my budget. I am thinking a 4 Channel and amping only 2 front speakers and the sub while leaving the rear 2 without AMP. Does this config make any sense?
Yeah you can do that. Check out a gmd8604, 4 channel Pioneer. Run the front 2 off the front and bridge the rear to run the sub.
Yeah you can do that. Check out a gmd8604, 4 channel Pioneer. Run the front 2 off the front and bridge the rear to run the sub. Look at getting the 1260 sub though, 4 ohm svc.
Product Brand & Model: I have a Mosconi D2 100.4 DSP amplifier and Controller for sale. It's 4 channel amplifier with a built in DSP. Condition...
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
Yep, i am going to put those audisons (rainbows dont fit) on original places front and focals to the Back end. I am going to give amp and corals...
I think I mentioned plenty of amps for the need. hopefully you were able to pick one up on the Christmas sales
4K
Guddddu
Guddddu
Santiago
CSCStang
