amp wiring kit
Thats what I thought, is there a specific kit i would need for a 5 channel amp? i have no idea what to order but I want to make sure i get the right stuff with everything the shop needs to do the install.
Also does it matter what kind of vehicle I have (ford f150)
Usually the amp's specs tells you the gauge needed for it. I would make sure I go with a known brand, since some cheap ones give you more insulation than wire and it's not the actual gauge.
The best kit is the one you can put together yourself and select the items, maybe this thread can help regarding wire, the link posted above is a good manufacturer, you can add extra RCA .'s if needed
http://www.caraudio.com/forums/wiring-electrical-installation-help/515724-wire-comparison.html
ihsballer20
ihsballer20
rochester, ny
Alrojoca
