Amp wire not enough?
45js45
Sons friend is running an audiopipe ap1800 with a single 8 gauge power....is he gonna damage the amp? What if it were a ap1500? told him he needs a larger wire but couldnt substaniate what damage it miht do to the amp with facts....please help.
Unless the battery is like two feet away from the amp, it should be 4 gauge minimum. I don' think he'll damage the amp, but he will melt the insulation on that wire at some point. This could result in lots 'o sparks and fire...
No, it won't damage the amp's power supply, but it could burn that wire up. Could even start a fire. Not SUPER likely, but possible. My recommendation is 2 gauge.
A power supply won't be damaged by too high a source resistance.
lol, even 4awg will cook in time, and still not pass current well....... hand him a straw and tell him to yell through it for a min. no breathing through his nose, or around the straw. then, hand him something like a 2"+ vacuum hose, or shipping tube and do the same... that is what the amp is seeing. the 8awg is only good for like 40a, depending on length, and over that, the voltage does drop, and the power supply circuits see a lot of heat from it, which also transfers over to the outputs, so yes, it can damage the amp. unless he plans on dropping under 400watts to justify using the wire, then time to upgrade.
45js45
45js45
lost.....again
akheathen
michigan born
    May 14, 2026
michigan born
    May 14, 2026
