Amp turns on then immediately into protect and it keeps doing it
Mell
The title says it all. I have an planet audio AC3000.1D and it just recently started doing this. Before this happened i had two amps hooked up and i had the one with the problem as the master. When i removed the other amp from my setup the problem arose. The amp comes on fine then makes a loud "thump" noise and goes into protect. All help will be highly appreciated
ive did that too, still no progress
So you're saying the amp still goes into protect mode with NO RCAs connected to the AMP input connectors? And your saying the amp still goes into protect mode with NO speakers connected to the AMP output terminals? If so, the amp might be bad. If not, explain where I misunderstood you.
Did you check for solid +12 on the remote turn-on wire?
usually, it's blown MOSFET's that cause this. the MOSFET's are connected directly to the supply rails and when they fail they short to ground. the result is a surge of current upon power-up which the amp recognizes and goes into protect.
Yep - I call that a "shorted voice coil simulator". Good news is that the protection circuit still works //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i looked at the back of the circuit board and it looked like some type of corrosion or something. its was also spots that looked black. I also check mosfets, they looked fine
That's flux. Get me a part number for each MOSFET on each side or a good picture ill tell you how to take them out and test them with a digital multimeter.
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
252
  • Locked
527
Amp
423
Mell
Mell
SE, Michigan
6inarow
    May 24, 2024
