bm2112
I had read many of the other similar threads prior to posting but none seemed to help me. Right now I have a Rockford P2D2 12" sub connected to an SPL amp. I have a Crossfire amp that works perfectly with the exact same wiring I have in my car. I can put all of the wires in my Crossfire the same way I do my other amps and it works great. However, I can't get sound out of my sub with my SPL amp or the two Power Acoustik amps I had before. All of my connections are secure. It has nothing to do with my RCAs not getting signal because my other amp wouldn't work if this were the case. No wires are touching. My Crossfire is a 2 channel amp which I bridge, whereas the other amps are single channel. The SPL amp I have is rated much higher than my sub, and I don't know if this could have an effect, but the ratings on cheaper amps are often exaggerated anyway. If I don't find an answer here I will probably take it to an audio tech, but even a somewhat reputable car audio company here told me my amp was defective. I listened to them and ordered a new one... and another new one. The amp is not defective. It is a completely new amp so fuses shouldn't be a problem. SOMEONE PLEASE HELP! Thank you
