amp/sub not hitting
If you have an alpine deck then turn your sub level to +15 and remember to set your gains. At 0 (factory default) Alpine decks will make it seem like your subs are off unless you have some major power then youll think something is wrong.
+1
check the ohm load if the config is correct
id check the ohm load, as well as the voltage from the rca's. any o-scope should do this. also, what is the airspace andtype of enclouser are you using? the box can make a huge difference.
robert2446
robert2446
houston,tx
YoungBloodM50
vegang
vegang
