amp / sub matchup problem? plz help
smanrocks
fla
i have an audiobahn 8002t amp
and i have 2 12'' kick cvr's running off it, which on the terminal says the are 2 ohm, so im guessing the two subs, run into the +, - terminal on the amp, and i have double up speaker wire, running from the +terminal to the + on channel one, and the negative terminal to - on channel 2 (so its bridged, exactly how instructions say)
amp cuts out i think its due to overload, or gain or somethihng
like the amp goes into protect mode, and I have a switch that runs to the accesory wire so i can directly cut the power to it, so when it goes into protect i just shut off the amp and let it cool down and i can turn it back on 5-10 min later and it will run for about 20 min before cutting out, depending on the songs. I have my headunit set to -2 bass, so i can't figure out the problem.
i dunno hwo to wire it parallel to the amp, so i think thats why it is messing up
any ideas? thanks
Those subs are dual voice coil subs. Meaning each sub has two voice coils, or 4 voice coils in total. Each coil can be wired individually. How do you have them wired? In parallel? If so, that would create a .5-ohm load on an amp that is only rated for 4 ohms when bridged (if those are 2-ohm DVC subs)!
the two subs run into a terminal on the side of the box, and then i have speaker wire running from the + to the + on the amp, for one chan, and the - so forth (bridging it). THe amp keeps going into protect. I have a switch set up off the accesory wire so i can directly cut the power to the amp to let it cool down. Do you think my alternator is what is making it go, or my amp isn't powerful enough.
smanrocks
smanrocks
fla
smanrocks
vegang
vegang
