Amp Opinions
bgowdy
Heroes are remembered, but legends never die
Ok so i currently have a Old Style Memphis Mojo 4KW. I have some one locally who is thinking about buying it from me. I can sell the Mojo and get a Audiopipe Aqx3500.1 which is still a good amount of power @ 1 ohm and still have about $150 left over after its all said and done. I only have about $325 actually in the Mojo anyway. I have came across clamp numbers will researching for the Aqx3500.1 and i was impressed by these. I also figure that it would be easier on my trucks electrical when it comes down to it. Seeing the AQX's fuse rating/draw is 250amps vs the Mojo 4k is like 400-500amps and me being able to keep voltage higher with the AQX i should get just as much if not the same amount of power out of the AQX anyway. Some of the 1 ohm clamps from it showed d@mn near 4k from it. So to me this does not seem like a bad idea. And please no Audiopipe bashers.
Thoughts?
@Flastrongman; since i know you have some EXP with them.
Thanks
you want the apk series audiopipe i wouldnt touch the aqx3500 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif overheating issues same amp as the rd audio 3250 look that up
i did and the models before 2010 were the ones that had that problem. They revised the AQX's and fixed that problem.
Yea but the 1 ohm clamp u saw from it was probably wired at .25 nominal and rising to 1 ohm and knowing ap is sone dirty clipped to shlt powee..save urself some disappointment and jus get a aq3500.1
actually wired from .5 rising to alittle over 1 ohm, 13.4v, and it was clean. yea im not finding a AQ3500.1 anytime soon for the price im looking for lol
---------- Post added at 05:45 PM ---------- Previous post was at 05:44 PM ----------
Q1-3500D.1 Amplifier
id rather not pocket any money and get the aq2200 on sale now with free shipping //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif or the apk3500 which is korean made audiopipe
Audiopipe APK-3500 3500W Mono D Amplifier : APK3500 : VMInnovations.com
Audiopipe APK-3500 Class D 3500W Monoblock Amplifier
why would i want to pretty much cut my power in half?
---------- Post added at 05:46 PM ---------- Previous post was at 05:45 PM ----------
in for responses....
hm..... it was that bad of a thought huh?
lol, no actually wondering about audiopipe. I keep hearing mixed reviews, so I wanted to see the responses here
will u be wiring @.5?
i mean i only hear mixes with the ap & apsm line doing dirty power or not doing rated. this line however did do rated + FOR SURE and was clean. Its pretty much the same board as a RD 3250.1 V2. the RD 3250v2 is a BEAST if you get one that doesnt blow. With that being said, when they were made a couple years ago there were some problems with it. Which Audiopipe had the AQX's revised and the problem corrected. Yea ive done alot of reading on them lol. but im just curious like you are. but of course since its AP, you know the rest
Aq3500.1 is on sale for 635 free ship cant beat that..and i wouldnt trade the mojo down to ap...yea the mojo is a current hog but at least it puts out the power
the mojo at low voltage isnt gonna have awesome output anyway vs the AQX staying above say 13-13.5v or more. even with these dekas the mojo is still gonna drop me down to probly mid 12s or lower.
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
209
412
493
bgowdy
bgowdy
Campbellsville, Ky
bgowdy
