bgowdy
Heroes are remembered, but legends never die
Ok so i currently have a Old Style Memphis Mojo 4KW. I have some one locally who is thinking about buying it from me. I can sell the Mojo and get a Audiopipe Aqx3500.1 which is still a good amount of power @ 1 ohm and still have about $150 left over after its all said and done. I only have about $325 actually in the Mojo anyway. I have came across clamp numbers will researching for the Aqx3500.1 and i was impressed by these. I also figure that it would be easier on my trucks electrical when it comes down to it. Seeing the AQX's fuse rating/draw is 250amps vs the Mojo 4k is like 400-500amps and me being able to keep voltage higher with the AQX i should get just as much if not the same amount of power out of the AQX anyway. Some of the 1 ohm clamps from it showed d@mn near 4k from it. So to me this does not seem like a bad idea. And please no Audiopipe bashers.
Thoughts?
@Flastrongman; since i know you have some EXP with them.
Thanks
Thoughts?
Thanks
