- Thread Starter
- #136
Did you add a larger ground to the body from the battery? The stock ones are only a braided wire with spring clips. I would also try undoing the ground block from the body so that it only goes through the frame ground. I had an older suburban that worked fine till I upped the amp then I started to have problems like what you are having, it just didnt seem like there was any more output.
Also I will mention that trying to check poor connections with an ohms meter may not always show a problem. There could be 0 (zero) ohms but when you try to run a few hundred amps through it, it just can not carry the power.
Forgot to mention that why I ask is that the body is isolated from the frame with rubber bushings.
Yeah I have big 4 done under the hood.
And using the floor pan as a ground was working fine, i just added the leads to the frame just to be safe. Also, only way for me to go directly to the frame ground and bypassing that ground block would be drilling huge holes in my floor. Want to avoid doing that.
I have plans after work to get this amp in another vehicle. If it does indeed perform, then it will be clear that theres a hidden variable somewhere in my truck. And at that point, i will switch everything up and track down the problem.
Just a slight hint is all im after here. Just an idea of where to start changing things. As of now, iv done everything besides change boxes and re do my power wiring. Ill know more this evening.
I actually pray it IS as simple as a power/ground issue. Have No problem routing more cable and adding a few more batteries if so....
