Gonna try and keep this short.
I just received My new DD m3b. Should be around 2500 RMS at 12v , upwards of 4k at 14.4.
Its not. I can tell it sounds like my T1000 i just replaced it with. Wont clamp anything above 800 watts.
I have no clue whats wrong. I originally thought my filters could be holding back power, iv tried every variable between the head unit and amp, no luck. Have set gain with scope and DDs method with just watching tthe clip indicator.
Now you may say maybe voltage isnt good enough. Well, i dont drop below 13.8 even on big burps. Specs are in my sig. What the fucc is going on? ???
I actually bought a different M3b off eBay and returned it for the same reason, thought it may have had some blown output transistors. Now, i either got a brand new amp with a switched out board, or im doing something seriously wrong (which is my guess, nobody can be that unlucky to buy 2 burnt amps back to back with the same issue. )
I need help. Im lost. Iv never ran into this issue in all my years. Im not a n00b, but not a pro either. I need y'alls help!
