amp help please
It may hang in there for a little while but you probably will see smoke in the end. If you want a new amp, give it a try.
you may or may not get away with it....i wouldnt do it personally unless it was ONLY for spl burps...
Yeah...SPL testing is probably going to be the only time you can do it, because depending on imp. rise and frequency used for the burp, the actual load seen by the amp is likely to be higher than 1 ohm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Otherwise, your impedance is likely to be under what the amp can safely tolerate.
john141005
john141005
Albuqueruqe, NM
JimJ
