need 2 amps please help!
air_odie
Well all I need to know now is which amps to get to complete my first system ever. So being a total newbie to amps and largely looking for a good solid two amps, that must have all the protection of thermal shutdown, overload, and the full line of other goodies. both amps will be in tight areas and need to be solid under less then ideal conditions.
The first amp will be for two incriminator audio Lethal Injection 10's http://www.incriminatoraudio.com/li.htm; I want to push these **** good as they are all thats in the rear...also highly interested in a bass control knob on this amp.
They are going in a MTX thunderform box.
The second amp will be used to power a set of Boston (Acoustics)Pro60's I want to push these at a **** hard rate as well. (http://www.bostonacoustics.com)
As far as the money side of it I have allotted up to 800 for both. please let me know what you suggest for the applications, where the best place to purchase them at is, and any specific information about them I should know. if you want more info feel free to see my post on "PLZ help me blow $3200: I am looking to purchase in about a week so....
Thanks
ODIE
You Don't Need Two Amps. I Got One Amp That Will Do The Trick. A 1800 Class D Amp Maxed Out A 3600 Watts Of Earth Punding Bass. Two Channels One Ohm Stable.$800.00 And It's Yours.
God you're stupid, CREATE A FOR SALE THREAD IN THE RIGHT SECTION, I'd also suggest you stop asking for WAAAAYYYY too much $$$.
The Pro60's are 3 Ohm components. This means you will get a little more power out of a unregulated stereo amp, as long as it is 2 Ohm stereo stable.
I think that you should look for a 100 or 150 watt stereo amplifier. I like this JBL:
http://www.cardomain.com/item/JBLPX6002
It is a little more power than what the speakers are rated for, but if you adjust your gains you will be fine and have great headroom.
For a sub amp, why not match it to your component amp with this beauty:
http://www.cardomain.com/item/JBLBPX11001Z
It's a refurb, but it will keep you in your budget and have a lot a flexability.
air_odie
air_odie
FLA USA
diatribe
