Amp has power but subs suddenly do not have output
  • 5
VolvoAcoustic
Canada
I've had this system for 15 years in 3 different cars. It has always worked.
One day a couple weeks ago I was driving and the subs turned off. I checked the HU, the RCA, I hooked the subs up to a receiver and they work, the amp has power and isn't in protect.
I ordered a new amp and the same issue.
The other day I turned the car on and the subs were working fine suddenly. I didn't change anything. The next day I went to test again and back to no subs.
The only thing I can think of is the amp is getting enough power to turn on but not enough power to push the subs? How would this happen suddenly and how can I test for that?
Could a bad ground be the cause? Nothing has changed ground wise. I don't understand.
Any ideas would be appreciated. Thanks
Fuse is fine yes.
Amp is Power Acoustik OV2-1200. Subs are 2 600w Super Blue.
I went out to check the sub make and realized one thing I hadn't tried is only having 1 sub hooked up. I unhooked the left and tried and wow, it's working. I then swapped the speakers and the other didn't work so I guess the one is blown then right?
So I hooked the one that worked back up and it doesn't work now either, even though it did just a few minutes earlier.
A sub can be blown and still read fine, ohm-wise. It's either that or too low of nominal ohm load on your amp. That's what I would look for.
See if when you push on your subs if you hear any rubbing. Look at the coils through the motor if you can, or the motor-basket gap, if there is one.
For anyone that finds this thread, it was an issue with the ground. Not sure why it suddenly stopped working but I cleaned up the paint and cleaned up the connections and it's working again
Check your remote line or RCA, some decks have written remote 2 times different wires one solid blue one blue and white, some do the misstake...
10
10
211
192
VolvoAcoustic
VolvoAcoustic
Canada
Buck
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
