amp for xxx
Any amp that is stable at 1 ohm is fine:) Considering how you can wire an XXX to 1 ohm;)
Look for something that does 1000+...by the way, what is your budget?
- Steve
Originally posted by loserpunk i've found a couple amps i was looking into....1200.1 tsunami 1100D..any other suggestions for about the same price...how do you get 1ohm???
go here - http://www.eatel.net/~amptech/elecdisc/spkrmlti.htm that should help you, but to explain it in words, cause i had to wire my sub twice to get it right, lol, just treat each pair of voice coils like 1 dual VC sub, and wire each pair in series, and each pair will have its own channel on the RE 35-1D, but i dont know about the other amps, you shouldnt have any trouble though.
Pat
ok i checked that out but won't you get a total indepence of like 2.34 ohms or something on a mono amp..//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif am i missing something???
E-mail RE or PM mattj to get the XXX wiring diagram...it shows you how to wire it to three different options.
- Steve
ok thanks....are all the xxx quad coils...for some reason i thought you could go dual or quad...but i think they're all quad ??right
well ne ways thanks for the help
Originally posted by loserpunk ok thanks....are all the xxx quad coils...for some reason i thought you could go dual or quad...but i think they're all quad ??right
I believe you can go either way if you contact RE, but dont quote me on it.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
245
456
loserpunk
hapbahdasindot
loserpunk
Elkhart, Indiana
paikiah
Decebal
    Jun 10, 2024
