amp for pro60se
boosted4
im pretty much set on the BA pro60se for my front stage, about $330 from woofersetc. im looking at the sundown sax 125.2 for it. i have 2 basic questions.
1. is this amp good enough for the components? from the site if you didnt know the specs.
Rated power output
----RMS power, 4 ohm stereo
125W x 2CH
----RMS power, 2 ohm stereo
200W x 2CH
----RMS power, 4 ohm bridged
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 50Hz ~ 5KHz
High Pass Crossover 30Hz ~ 3KHz
Variable Subsonic Filter 10Hz to 500Hz
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
THD@RMS Watts
Channel Separation 75dB
Fuse Rating 20A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 340(L)mm
2. when i hook the amp up, should it be tweeters on 1 channel and drivers on the other? or 1 side 1 channel? idk if it makes a diff. either way
thanks in advance for help... extra thanks for the most helpful response //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Left channel will go to left crossover which goes to left tweeter and left woofer, and right channel will go to right crossover which goes to right tweeter and right woofer. Don't worry about the ohm rating, the SAX125.2 will power 3 ohm fine. The power will be about 160watts/channel.
Edit: At $300 for component speakers, why not take a look at other, less mainstream brands? The DLS UP6i's are great, and so are the Image Dynamics CXS64 V.2's.
i figured those would be a solid choice, i dont know much about car audio so im still open to suggestion as far as a component set goes. my price range is 3-400. i just dont want the tweets to be piercing... warm but loud i guess. i listen to mostly hip hop, r&b occasional rock but nothing too heavy. ive looked into the id's a bit and there seems to be alot of people on hear who like them.
mainstream, underground whatever, i dont care about names, just what sounds good for the money im spending
boosted4
boosted4
braintree, ma
boosted4
Mike Mccabe
