Amp For Mystery Sub?
  • 2
SuperNoob8
Hello, I know nothing about subwoofers, but I bought this box at a flea market for $5 because it looked cool. I'd like to find an amp for it, but I have no documentation.
I honestly can't find much info about it. I measured the subs to be 8" and found this sole post via Google:
https://answers.yahoo.com/question/index?qid=20110616074950AAZBEmh
The comments in that thread lead me to believe that the speakers are 150 RMS each, which seems rather low despite their age? There is a single set of terminals so they are SVC. Correct me if I'm wrong:
Currently they're wired separately, but if wired together that would be either 2 ohms or 8 ohms of impedance (I think)? That, and whether the tweeters affect anything, are what confuse me about finding an amp. All help is appreciated!!
what you want is a "monoblock" id say 200w @2 ohm brand any major brand will be more than enough for this application id bet $60 shipped you could get something
I lied get a 2 channel full range amp(i only seen the woofers before) 50w "rms" and up per channel at 4ohm will work same price applys
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
236
440
SuperNoob8
SuperNoob8
Virginia
kramer_212
Decebal
    Jun 10, 2024
