That don't mean the caps can store enough to hold it there for long.Hmm.. Wasn't at least 1 FSD amplifier put on a Dyno?
IF i'm not mistaken, wasn't it's dynamic measure respectable?
If i had access to one of their monos, i could put it on our system to measure FR all the way down to 1Hz and post it's results.
you need to serious understand what it is.. its measurable and it does make a difference. the way some manufactures measure it can be misleading but its simply put the output impedance and capacitance. the lower resistance transistors and lower tolorance high capacitance cap backs are going to offer a high dampening factor.You can't even measure it until it's down to single digits. It's marketing BS
Shut up no it's not. It's bull ****. Anything over 50 is great.you need to serious understand what it is.. its measurable and it does make a difference. the way some manufactures measure it can be misleading but its simply put the output impedance and capacitance. the lower resistance transistors and lower tolorance high capacitance cap backs are going to offer a high dampening factor. you can hear the difference..
BUTSHIT. the inductance and motor strength on the new high output speakers Are way higher than previously. so the feedback is MUCH greater..Shut up no it's not. It's bull ****. Anything over 50 is great.
Man I love how Andy words stuff.BUTSHIT. the inductance and motor strength on the new high output speakers Are way higher than previously. so the feedback is MUCH greater..
Ive read all of that. YEARS ago.Man I love how Andy words stuff. Here's your feedback
Myth Busting: Damping Factor - A Misunderstood Rating
---------- Post added at 09:46 PM ---------- Previous post was at 09:45 PM ----------
Now go away and only come back to talk about the woofers you are designing to be the best ever.
So this is why you and half the world is dumb? This is how linear power sells amps to idiots.we are talking 2ohm and 1 ohm and half ohm loads.. not 8 ohm loads. and the feed back on the modern speaker far exceeds what was previously tested..
