American Bass XFL or HD 15" for my 1500 watts?
RSDXzec
I have an APSM-1500 and I'd like to know if it's worth getting the HD15 or if the XFL15 should theoretically be louder on this amount of power due to less power handling + xmax therefore higher efficiency.
I've also never pushed a sub over RMS power which is why I'm considering the HD15 as well.
I'm looking to tune around 30hz with a 4.5cf box and lots of port area. (I have around/slightly over 6.6cf gross to work with)
Cheers.
If you are open to suggestion you might want to look at these C2 Threatcon also 3 inch voice coil same as the XFL but price is only $129 free shipping to CONUSA.
HERE'S THE INFO
Threatcon Sub 12" 600watt $129
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
If those are the only 2 you are looking at i would go with XFL, you can always go bigger on amp later on and it will not hurt the sub if you give it less power than rms just dont over clip it.
good luck
RSDXzec
RSDXzec
Australia
naughtyca
    Jun 24, 2026
    Jun 24, 2026
