American Bass XFL 12's power question
So, i have 2 SQ Q1-2200.1's and i was wondering if the American Bass XFL'S can handle the power dished out by these two bad boys linked. They're D2's. I want to wire at a .5 ohm load if using just one amp. What will one of these amps do at .5 ohms on a good electrical? If i can get 3k out of just one i'll just let the other sit until i need it.
Yes they can take the clean power from 1 2200 @.5 ..depending on rise it will put out about 2700rms..if u feel u need more power and they are handling a single 2200 fine strap both at 2ohms (1ohm per amp) and they will really get to moving ..gota be careful at that power tho..cant have a crazy big box or play insane below tuning
Well my box is about 6.25 cu ft tuned to 27hz. Do you think they will be okay? My ultimate objective of all my installs is crazy low bass that most people dont really get a chance to hear. My pioneers were extending down to about 22hz before they started losing pressure from the box. I heard these XFL's get pretty low too.
6.25 after port and subs displacement?? If so thats way too big ..what are the dimensions of ur box?
Its 6.25 before sub displacement but after port displacement . I think the dimensions are 32X27X14. I forgot the exact dimensions.
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
I have 2 of them in around 2.5 cubes per sub, tuned to around low 30s Hz. I think.its tuned a little low. Really low frequencies hit thick and...
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
Jkidd288
Jkidd288
Greensboro, NC
Jkidd288
    Jun 1, 2024
    May 31, 2024
