Am I set up to 1 ohm ?
dual 4 ohm subs?
on 1 sub , connect the pos to the other pos and neg to the other neg. you should then have 1 wire from the pos and 1 wire from the neg connecting to the terminal of the box.
do that for both subs. test the terminals you should see a 2 ohm reading. 2 dual 4 ohms wirted that will with show 2 ohms at each sub which will then be seen as 1 ohm at the amp.
Ohms are determined by either running in parallel or in series.
Parallel = Positive to Positive
Series = Positive to Negative
When running parallel you cut the ohms in half.
When running in series you double the ohms.
When you have multiple voice coils, and multiple drivers, you can combine parallel and series configurations until you get your desired result.
Without specifics on your driver we can not help you, can you post a link to the product page?
Looks like I'm a little slow //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Nice!! If you cant find a way to wire some subs up off here..you got problems..lol..I cant believe there isnt a sticky for wiring configurations on here
---------- Post added at 08:40 PM ---------- Previous post was at 08:40 PM ----------
Pics!!
Audiobahn, your drawing is for a monoblock amp? The drawing I put up seems to suit my needs. I have 2 12"s HE2 RFP4212 which are DVC 400rms @ 4ohms.
I followed the drawing I posted and it sounds pretty good but will have to test tomorrow. I had it set up like audiobahn posted in the link but the ohm reader was reading 3.5 ohms so I had to look further .
Wait, it's the same thing, lol - so I should be good now. It ***** doing everything in short spurts. I was just out there with a flashlight in the dark, lol. Think it's good though, I'll update tomorrow
mrpep
mrpep
chicago
mrpep
Mike Mccabe
