Alternators-Newbie
Hey guys whatsup iv been told that with the sound system i want its better to go with an HQ alternator than extra batteries. I have a 1999 F-150 extended cab lariat 4x4. 5.4L triton. I don't know if that matters but yes i do need to do more research and i don't wanna here complaints from yall cause I'm a newb. Just please suggest and help me find a good alternator for my truck.
Thanks you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
This is what i have found so far.
http://www.qualitypowerauto.com/catalog.php?category=5
If you are running under 2k watts rms @ 2ohms you can really just run a zero gauge big-3 install and a nice deep cycle battery under the hood for insurance.
No extra batteries..
No high output alternator..
Just a big-3 for voltage issues, and a nice D31 Optima to replace your stock battery.
Your stock alt is either a 110 amp or a 130 amp iirc meaning you have between 45 and 55 amps to run your system on the stock alt..
A clean 1,000 watt amp pulls around ~50 amps.
Therefor you don't need an alternator.
If you choose to go 1k watts rms or higher @ 1ohm you will need to upgrade your alternator. Then depending on your listening habits, you might need to add a battery depending on your voltage dropping issues, if you're having any.
Reece Cook
Reece Cook
Gonzales, Louisiana, United States
Reece Cook
BP1Fanatic
BP1Fanatic
