Alternator Whine ONLY Coming Through Front Tweeters...
  • 5
Orion Man
Livin' Loud!
Hey all, I have a Diamond Audio M3 6.5" component set for the front stage. I was playing with the fade, and the alternator whine only seems to be coming through the fronts. But, its not through the mids in the doors, its through the tweets in the dash?!
Any clues?
Everything has 14awg wire run throughout. I have checked and even changed ALL possible grounds that I could. The crossovers for the fronts are mounted under the front seats. The speaker wire is run up the middle of the car, the power on the pass-side, and the rca's on the driver side.
I'm stumped. I even went to the extreme of changing out the ground on my battery. I thought that was the problem until I figured out it is only coming through the tweets today. I never had any alternator noise when the system was in my Accord. Now, its in my Integra and its got all kinds of static and whine.
Please help! Any advice would be great! //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
i would mess with the gains. Turn the gain on everything all the way down. Turn the volume to 0. Turn up the gain until you get that whine(interference). Adjust the gains for everything else accordingly. That is what i did and it fixed my problems. Although, my interference wouldnt fluctuate with the alternator.
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
764
I don't have one...but I check my voltage with a dmm once a week or so
851
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
What the ****? Are you trying to put ohm's law into very complicated verbiage?
Orion Man
Livin' Loud!
Orion Man
Everywhere
budahbuddy803
    May 12, 2024
Brendon Jenness
    May 11, 2024
