Man, who's got time to watch dvd's when you're driving that thing!?
Your calling yourself a professional alarm installer and you recommend using a test light?im going to tell you this...
if u was a professional alarm installer like me you wont even NEED the wire code sheet unless u want to do things fast. because its a ferrari i wouldnt take my chance to find out somebody else work on installing alarm on that. i would actually take my time and use a tester light or DMM. for door pins u'll find the pin or wire inside the door/door jam and find which wire give out voltage when door is open/closed. trunk, and hood pin. if u can get behind the pin and see the wires then it'll be easier. the power wire and ground is pretty easy. the next thing to do is find the parking wire light for it to flash you'll find it behind the switch and the horn around the steering column. not much left to do put run the wire into the firewall and install the siren.. ohh yeah i almost forgot. the power door unlock and lock. use ur tester light and see if u can unlock and lock the door. if u cant do one of them ur gonna need a DMM to read how much ohm and buy a resistor..
later.
im waitin to see what you gon say.. JUMPER WIRE? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifYour calling yourself a professional alarm installer and you recommend using a test light? Are you serious?
test lights should never be used in a vechicle, esp a new vehicle. This is not the 70s anymore get a DMMim waitin to see what you gon say.. JUMPER WIRE? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
yes . TESTER LIGHT
yes . TESTER LIGHT
lol....a test light works, but it is old technologytest lights should never be used in a vechicle, esp a new vehicle. This is not the 70s anymore get a DMM
