Python 5106p automotive alarm system
I have done something to lock my alarm system (it's in a 2008 Winnebago that I just purchased...).
The ignition is locked to where the vehicle will not start or even turn on accessory mode. The FOBs are not recognized. The battery tests a full charge.
With the RV electric plugged in to the house it will start with the 'battery boost'.
Please help....thank you.​
It sounds like you're dealing with a potential issue with the alarm system or the ignition lockout feature in your 2008 Winnebago. Here are some steps you can take to troubleshoot and resolve the problem:
  1. Check for a Manual Override: Many alarm systems have a manual override feature. Look for a keyhole or a specific sequence for overriding the alarm. Consult the owner's manual for the RV and any documentation for the alarm system to find override instructions.
  2. Inspect the Key Fob: Ensure that the key fob's battery is working. Even if the fobs are not recognized, replacing the batteries might be worth a try. If you have a second fob, test it as well.
  3. Reset the Alarm System: Disconnecting the battery for about 10-15 minutes can sometimes reset the alarm system. Make sure you have any codes or radio presets backed up, as you may lose them.
  4. Check Fuses: Inspect the fuses related to the ignition and alarm systems. A blown fuse could be causing the ignition lockout.
  5. Look for a Hidden Kill Switch: Some alarm systems come with a hidden kill switch that disables the ignition system. If you know where the alarm system was installed, look for any small toggle or button that might be a kill switch.
  6. Use Battery Boost: Since you mentioned the RV starts with the battery boost when plugged into a power source, make sure that the house battery system is functioning properly and supplying adequate power. This can sometimes indicate a larger issue with the vehicle's electrical system.
  7. Consult a Professional: If all else fails, it might be best to consult a professional who specializes in automotive security systems. They can diagnose the issue and help reset or reprogram the alarm system to regain access to your vehicle.
If any wiring modifications or changes were made previously, it's also worth checking those connections to ensure everything is functioning as it should.
How much volts does the Alarm System need? It is drawing too much volts off the battery and sharing it with the ignition system. If so, you need at least 12 volts - 14.2 volts to start the car off ignition. You're not getting that amount with the alarm system plugged in. By resetting it to default that may still not work. Find another way to power up the Alarm System.
Plus, I think the car works on two power up systems. It never has a not power on. Always powered on. So an auxilary battery at power off still will not work. Need more power to it yet.​
Thanks for the suggestions. It turned out to just be a bad battery. Replaced that and I'm back on the road!
greg chronister
CarAudio.com Newbie
greg chronister
Kimberling City, MO
greg chronister
