air bubbles
  • 2
jinx8402
RI
I am building kickpanels for my Vifa PL mids, and while making the back molding I got some air bubbles. They aren't too bad though. I figured since it is only for kicks and not an actual sub box that it shouldnt be too bad, right? Well this was my first time using fiberglass, so I guess it was a good learning experience.
To answer your q's:
1) They aren't too big, just big enough to fit the 6.5's, since my car has the pedal type e-brake, not too much room.
2) They are right in the corners where kickpanels are typically made.
3) I only put 2 layers down so far, but I plan on putting a third, especially in the areas where it bubbled up.
So with this info, do you think it is ok that it bubbled up a little bit?
Oh yeah, if you're at all worried about it, you can just put a sanding bit in your dremel, sand the air bubbles off, then glass over the area.........or you can start over. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Oh, well there about 2 air bubbles, but they are both about 1/4 long by 1/8 wide. One is near the top, about 1 1/2 from the top, and the other close to the center, but near the bottom more. I like the idea of sanding them off and putting another layer down on top. I was actually thinking of doing just that.
No don't apologize I totally understand and the information you provided helped alot
32
Look at the Alpine Type S subs.
19
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
jinx8402
jinx8402
RI
jinx8402
    May 12, 2024
Brendon Jenness
    May 11, 2024
