aeroports need the same lenght?
Xprime4
****in' canadian
well my sub just can't fit in the box coz there is like 2inch of aeroports in the way. Can i just cut it and expect little to no change in tuning?//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
i got 4 4inch x 18 inch ports in a 7.3ft/cu enclosure before displament
well the box is already done and redone ... no space for aeros outside of the box. Lets say trunk is no more //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well i'll try it anyway to see what it sounds like
no more comments? it seems like the shorter aeros push a lot more air than the longer but tuning wise it doesn't sound bad.
So do the aeros need to be the same exact lenght? or can i check tuning by adding their total lenght and divide by 4 ( i've 4 aeros)
couple hz difference. to daily it will tune it a little higher. if you dont like the sound of it you can always think of a different idea. but try it first, because its simple
well my big amp blow last week and my bxi2006d will get here soon. So right now i'm pushing it with a ma audio amp 500 watt amp that **** hard and well i expected more sq from the Q. I'll see later and might just seal that box if i don't like the sound
If it were me , I would remove 1 of the ports and retune the rest.
yeah good idea. So with one aeros, they said i'm gonna need them at 13.92 Inch to make the box at 30hz. Less aeros = shorter one too //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Anyway i'll be doing this if it work for sure //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
my box is 6.5cubes with 4 4" aeros and i have one plugged right now so its tuned to 30.5hz i dont hear any port noise. if you made all 4 about 12.5" long you could plug one and tune it to 30hz and 35hz
what you mean by plugg? remove the port and seal the hole? got pics of your design
http://www.edesignaudio.com/product_info.php?cPath=1_76_101&products_id=762
Xprime4
****in' canadian
Xprime4
Quebec, Canada
Xprime4
