Round Precision Port diameter?
Single 4" aero port at 17 inches long would be good. I have mine 2.5 inches from my back wall in the box but some recomend having it 4" away from the back. For the little testing i did i have zero port noise but i wont know for sure until i get some good air moving.
I probably won't have enough room for 17". The calc says about 16 inches but my box won't be deep enough to have clearance between the port and the back of my box. Is there a way to turn the port inside the box?
You could maybe see what you can use for shorter ports. You can run a single 3" port at 9.5 inches. Just remember that it will be longer because the flares add length but they dont count for the length you need to get your tuning.
a single 3" at a shorter length would be optimal but would that give me port noise? Aren't the precision ports supposed to help eliminate port noise?
I dont think there would be any issues with a single 3" port at that length using flares but im not positive.
No other option really besides a slot port.
He could probably get away with one 4" port, but I wouldn't do it.
Yeah he could but then he will lose some more space inside using a slot then ports. He says 2 cubes but i dont know if thats net or if his goal is to get 2 cubes after displacments. He could also use two 2" ports at 9" long wich would maybe be like using a single 4" instead of the 3" one i suggested.
Two 2" ports is half the port area of one 4", which is why they only have to be 9" long.
Two 2" ports is less than half the port area of one 4", which is why they only have to be 9" long.
Interesting to know. What are the dimentions you have to work with OP? You could try to use some rings on the outside to extend the ports out further so they will fit. It may look a little goofy though.
Two 2" ports would be half the area of one 4" port... You can use a 90 degree elbow from Home depot or lowes to bend it. I would say go with the 4" port, you'll be glad you did. 3" would work, but you'll be holding your sub back.
ive heard that technically you only need roughly half the port area using aero ports compared to slot ports.. 1 4" should be ok then?? tommyk, what would you suggest for 6cf with 2 15"s? (nightshades) 4 4"s for daily?
tooshort_128
tooshort_128
Sterling, VA
tooshort_128
BP1Fanatic
BP1Fanatic
