AERO port help
port displacment is more than .08 im pretty sure i did the forumla right on the above qoute. .34 plus .25 sub displacment
4" ports and 6" long two of them
2x2x3.14=12.56x6" long=75.36/1728=0.04361 is disp for one port so two would be 0.0872
not sure where you are getting .34 my 6" aero 10" long only took up .16
why not use an 8" aero or a single 6" for just a bit more port area??
cant use an 8" aero only pvc. remeber i am covering a slot port with a face with aeros. the opening is only 8"wide. 8" aeros are wider than that at the flare. i think i am going to go with 2 6" aeros for a little over 50 inches of port. that should be close to minumum spl port area
12-16 per cube. In your box you would need at least 3 4" aeros and 4 would be better. It'll work but might have port noise or not get low.
If you can somehow make those 4"s to 6"s and use 2 6" aeros you would have enough
That is slot port, not aeros.
You can use 2 4" aeros. You can also get pvc pipe possibly to use to make the aeros longer. I'm not sure if they will fit inside of the ring that attaches to the flare, but it might work. I would go bigger if possible. Say 3 4" aeros. Or a 6" or two. Just makes sure that your box doesn't become too small.
no one is getting it lol kill this thread please!!!
he wants to tune higher i.e. shorter ports but he's already @ flare to flare
hell just take inner flare off just use the outer flare as entire port lol no flare on inside but still efficient lol will do what you want lol FTW give it a shot
no one is getting it lol kill this thread please!!!he wants to tune higher i.e. shorter ports but he's already @ flare to flare
yea ppl cant read i guess. thanks for actually knowing wtf im tryin to ask lol. i was gonna try one flare but i was scared of losing efficiency and turbulance to cause a score loss. i will give it a shot though i dont have any other choice lol
if you do that, put the flare on the inside of the box and have the non flared part of the port external
basscort2009
Banned
basscort2009
dallas tx
basscort2009
    Jun 20, 2026
    Jun 20, 2026
