Adire Audio Brahma for home use
supermaxx123
I.E.
I was thinking of building a box for my sub to use in my living room, it's the 15 MKII.
I was going to go with 7cu/ft tuned to 24hz with 55"^2 of port area.
Would this work well?
It's mostly for music, movies maybe in the future.
here are the specs for the sub:
Parameters
Fs 26 Hz
Qms 5.5
Qes 0.51
Qts 0.47
Vas 113 liters
Znom 1 Ohm parallel
Re2 0.75 Ohms parallel
Le3 0.45 mH parallel
BL 15.9
Sd 749 cm2
Xmax 28mm one way linear
Pmax4 1600W RMS, 4800W peak
SPL5 87.6 dB @ 1W, 1m
Diameter 15.5"
Cutout 14"
Depth 8.25"
Volume 0.18 cubic feet
Lots of people use brahmas for their home theater sub I dunno how big but I know you would need a big box if your underpowering it nice low end monster tho should sound sweet
I have it in a 4.6cu/ft tuned to 29hz right now and yes, its loud and get somewhat lower, lower than most subs I've heard. but according to WINsd it peakes somewhat high. I'm going for something with a smoother response that will play lower.
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
208
supermaxx123
supermaxx123
I.E.
supermaxx123
    Jun 1, 2024
    May 31, 2024
